With the onset of nasty looking weather upon us all, now seems like a good time to ask about all the in's and out's of this button and what and how it works.
Now, when I got stuck at the beginning of the year, I tried this out to see what it did, it apparently made all 4 wheels spin, instead of just one (I was very stuck) and once they had spun for a few seconds it switched itself off, and on one attempt, the ABS light came on and went off again, which I think makes sense as the ABS was detecting certain wheels spinning and others that were not.
My main questions about this are:
Does the above sound like mine is working properly?
How does it work?
What speed can it be "activated/deactivated" if any at all.
Can it be used for keeping the car in motion or is it just for getting you going?
Your replies will be much appreciated, as I have no idea whatsoever about it.
Mark (4WD-virgin)
How does it work?
Mark (4WD-virgin)
lol when you switch it on the abs light will come on and when you go past 15mph( i think) it switches itself off.... unless you cut the blue/white wire, then it will stay on. so YES it sounds like yours is working as it should
