AAN gearbox in to 3B
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    hello peoples, does anyone knows if its very possible fit perfectly the original 6 speed AAN gearbox in to a "3b" engine??? i can have the front subframe of a 2.6 V6....it is valid for put in with my 3b engine +aan gearbox??? i know if i decided to build it ,i will need the ABY gearlinkage true???
    thanks for all replies friends
    Tomas
  • gnutz2
    • Aug 2006
    • 928
    The gearbox is longer, so you`ll need a propsaft off an aby coupe too.
    The ONLY S2 Golf!
    http://www.s2forum.com/forum/showthread.php?t=19402
    10.42@138mph
    https://m.youtube.com/watch?v=0wnkkOfFpXg
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      THANKS Gnutz2 ,i see...problems,maybe i must think in forget all about this and if one day can buy other gearbox like the ABY or RS2...
      • leo
        • Dec 2003
        • 101
        • Country: Poland
        Yes, I have 6spd gearbox from RS2 attached to 3b engine - the propsaft must be shorter.
        OOOO
        www.AudiKlub.org - the oldest and biggest Audi Club in Poland :thumbs:
        • BRY
          • 3755
          Any six speed gearbox would need a shorter propshaft.
          You also need the gearbox mounts from a six speed S2 / RS2.
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            ,AND ,thinking in buy the ABY propshaft and gearbox mounts... someone know how much can be for this parts???
            The RS2 propsahft is not valid for my possible proyect true?? ,ONLY just the ABY..
            thanks for all for the coments
            / Tomas /
              I was speaking to Newsh about his 6 speed conversion and he used the front section off an avant and the rear section off a 3B so assuming an RS2 prop is the same you could use just the front section if you have one. I'd speak to Newsh if you can though as I've not done this so can't comment on how it all fits together.
