Sticky Clutch Pedal?
  • rallyejames
    • Apr 2008
    • 129
    Hi There,
    Dont know if anyone can help....Clutch pedal seems a little sticky???
    It all works ok apart from when you release the pedal it only comes up half way..and then to bring it to the same height as the brake pedal you have to pull it up with your foot!
    I have had a look in the foot well and it all seems good.
    Is this a common problem?
    Thanks James
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by rallyejames
    Hi There,
    Thanks James
    One of cylinder seals is telling you, that it has tired already. Which one - master or slave, I can not tell.
    Sau
    • prosty
      • Jun 2005
      • 1114
      Air in the system, or faulty master / slave cylinder. Try venting the clutch, you can also adjust the pedal by the floor.
      2004 9-5 aero
      2009 Subaru Legacy Diesel
      1994 Toyota Supra Eurospec 6-spd LHD
      3-4 Audis in parts
      • Fat Audi 80
        • 10547
        Master Cylinder pushrod, imminent failure I would suspect. Check your Master Cylinder under the dash as a first port of call.
        Cheers.
        Steve.
        The Perfectionist
          What Steve said. I replaced my master cylinder to cure this as you have to remove it but I'm sure that was a bit OTT. There's a knuckle joint half way along the pushrod, the rubber perishes and it loses integrity. Removing the knuckle joint and replacing with a solid bit of bar is best.
          • HPmuirt
            S2Forum April Fool
            • Apr 2005
            • 3014
            Yup, agree with tweedle dumb and dumber above
            The pushrod on mine snapped within days of the pedal starting to stick, leaving me stranded in France. Get your head in there and inspect the pushrod now and I bet it is bent.
            Cheers n
            Si
            Subtle mods here and there
            2011 A5 3.0 TDi - Lava Grey
