Heavy Creaky Clutch ABY
  • re2500
    • May 2007
    • 2185
    Why would my clutch be fairly heavy and creak (creaking coming from bellhousing area)
    I expected the clutch to be a bit heavier than before the conversion, but this is really quite heavy.
    I am using ABY Master and slave, ABY DM flywheel. And i have no idea what clutch is in it?? The donor car was fairly standard so i doubt it has a performance clutch.
    "Difficult is worth doing"
    Old clutches are heavy as hell. If you put a new OE one in then you'll not be able to drive it as it's sooooo light! Can't think of much else you can do I'm aftraid. Oh, and put a SM flywheel in there as the DM one is toss! Looking at £200 for clutch and secondhand FW.
    • re2500
      • May 2007
      • 2185
      Argh. toss!!! I was half expecting that answer.
      Right, its off to the 'ring on the 14th. Ill see how i get on with it till after then, and then make a judgment.
      Ill probably whip the engine out close to the end of the summer, and fit an new slave cylinder and a new clutch + SM flywheel. Balls... wish i'd done all that when the engine was out.
        I thought you were going to use the CQ one?
        • re2500
          • May 2007
          • 2185
          CQ clutch wouldnt have handled the power. I dont think anyway.
          • re2500
            • May 2007
            • 2185
            U comin to MRC still?
              Thanks for the offer James but going to have to give it a miss, still experiencing a loss of power on all cylinders... hopefully it'll clear sooner rather than later
              • re2500
                • May 2007
                • 2185
                OK no worries.
                Im gonna bring that grill in to work and give it to Al tomorrow, as he said he might pop in and see you sometime soon.
                • s2driveruk
                  • 12696
                  try bleeding the slave if its not been done before, might give it a new lease of life
                  1992 3b S2 Coupe
                    Good advice but as it's all just been fitted I would assume he's just done that .
                    • K Simmonds
                      • Dec 2007
                      • 7632
                      Sounds like it could be the clutch release bearing. Had the same symptoms on my 10V coupe, can you hear a slight werring noise when engaging and disengaging the clutch?
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
