I emailed Javad yesterday about the juddering i get after mounting the rear diff alloy mount.
What i get is as soon as i go WOT and full acceleration,you get a feeling as if the rear wheels are spinning,although they are not.You are feeling a juddering at the back while accelerating.
Javad mentioned that i should only feel the whining of the diff while driving and not any juddering.He mentioned that maybe my driveshaft might not be alignhed properly or something.
Now by driveshaft i suppose he means the propshaft.We did have this out to replace the bearing and i know it has weights in it and it is balanced.
How can one check if that is mounted properly?Is there an easy way?
Also if that is ok,what else could it be?
The rear has new bushes(OEM) and only the subframe bushes have stayed the same,as they werent all that bad in condition.
