OK Help
Diff lock does not engage.
I have read all earlier posts. but still not cured.
I have had the car on the ramp and actuator moves freely and does lock rear diff as it should.
I have had the rear seat up and checked for leaks.
I have swapped the diff vacuum control unit
If i feed the pipes direct from the violet vac pipe it lights the switch and operates the diff as it should.
I have also used a different known working diff lock switch.
But still I can't lock/unlock the diff direct from the switch.
Does anyone have a wiring diagram so i can chase the wiring next???
Or do you have any other ideas that i have missed??
