6 Speed Box Driveshafts
  • paulmac
    • Dec 2006
    • 306
    Hi guys, has any1 fitted a 6speed gearbox in2 a ur quattro, im havin problems with driveshafts they appear 2 b 2 short, gearbox is from audi 100 s4, has any1 did this conversion and had similar probs, HELP PLEASE,many thanks paul
  • paulmac
    • Dec 2006
    • 306
    6speed gearbox driveshafts
    Anyone ?
    • mcandmar
      • Apr 2004
      • 5118
      Are you using the original front drive shafts? In an S2 they are different lengths for 5speed and 6speeds.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • AndyP
        • 6049
        Are you sure about this? I'm fitting a 6spd into my 3B soon and according to this post from Jeffer, the 3B ones fit
        See post #6.
        • mcandmar
          • Apr 2004
          • 5118
          Not anymore now that you mention it, ETKA does list the same part number for both. Very strange, I have it written down in my notes as being required, i even bought a set for my conversion
          • paulmac
            • Dec 2006
            • 306
            driveshafts
            im useing standard ur quattro driveshafts, seems they are 2 short
            • vader s2
              • Mar 2008
              • 141
              See post #6.
              if you are puting a ABY 6spd gearbox into a 3b, it will fit no worries. however you will need a ABY linkage and driveshaft also. i have done this already to my own 3b last year.
              paul
              • paulmac
                • Dec 2006
                • 306
                My car is a ur quattro with aan 6 speed gearbox fitted,
                • 20Vcqdriver
                  • 829
                  Shafts
                  Mine is a series 2 Cq with a 6 speed so not sure if / what differences there are but I found the series 3 7A 20v quattro shafts fitted after swapping the CV joints over. Will make enquires with someone who will know for sure...
                  1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                  • paulmac
                    • Dec 2006
                    • 306
                    Cheers, would b a big help, i know the front drives in a ur have a bigger diameter than a cq,also the hubs themselfs are different, any advise welcome,thanks paul
