I have a ABY S2 Avant, whilst coming home on saturday evening I lost all gears when making a gearchange at about 5k, I coasted to a stop and tried to select it idling without any luck.
Eventually after it was off for a while I managed to get it into 3rd and went to start it but it just tried to drive off in gear so I assumed the clutch release or something along those lines had failed ?
Today I had the time to take a better look at it, I checked the adjuster on the pedal which seemed fine, the hose clearly seems to be holding pressure fine and there are no visible leaks ?
The clutch slave runs on the same fluid as the brakes if I am correct ? the resevoir is still full although I will be honest it looks like its long overdue a fluid change in that department ! Is it possible to boil the clutch fluid ? I'm trying to rule out most things before removing the gearbox.
Whilst pressing the clutch earlier a friend send you can see movement in the clutch/flywheel area through a small inspection hole, I'd presume this is normal as there is no noises when running so nothing is loose inside the bellhousing in my opinion, you can clearly here the release bearing pressing on the plate when you press the pedal, to be fair it sounds quite noisy but I rarely if ever take note of what it sounds like that its usually running so I struggle to hear myself let alone a creaking clutch.
Any advice from someone who has had similar problems would be appreciated, ideally I don't want to have to remove the gearbox as it looks to be a PITA.
Regards
James
Regards
James
My S6 has just done a very similar thing
