I am removing the gearbox on the car in my Sig.
On the gearbox removal guide I downloaded from somewhere it says to undo prop and driveshafts at the gearbox end - Hmmmm?
So far, I've removed the 6 bolts and double head washer on each front driveshaft output from the gearbox and they still don't want to seem to move?
I have removed 3 of the 6 bolts on the gearbox outlet to prop shaft joint but thought I would come first, before going any further, to ask this question???
What do I need to do further to disconnect the prop and driveshafts from the gearbox so I can remove it?
Jim
Jim
