Heavy vibration.
  • meep
    • May 2005
    • 203
    Heavy vibration.
    Hey.
    Managed to kill a rear CV joint when launching without the rear diff locked.
    Had some trouble locating a new one that would fit so i bought a used complete drive shaft instead. Worked out much cheaper to. When i ordered the used drive shaft i made sure that i ordered the correct one since right and left are different length.
    Fitted "new" drive shaft. And when i go upwards of 25km/h i feel a thud thud thud in the chair. I cant hear anything but i can feel it.
    Now the million dollar question. What is it that is not right? Turning makes no difference. I think it comes on more when going into dips.
    Been suggested its the prop shaft but cant really see that since it didn't do this before and the prop hasn't been down. Some say that the rear diff is pretty easy to kill when launching without it locked. So that i should change that.
    Id rather not start to change parts at random though since thats usually pretty expensive
  • red leader
    • 58
    Wow!!! in 20 years of fixing cars i've never seen that..
    • meep
      • May 2005
      • 203
      1bar boost 5500 RPM launch with sintered non sprung clutch.
      • prosty
        • Jun 2005
        • 1114
        LOL have you been fixing cars under a rock (J/K) this is a standard Audi failure when playing around, since the brilliant engineers chose to make the outer joints hollow...
        2004 9-5 aero
        2009 Subaru Legacy Diesel
        1994 Toyota Supra Eurospec 6-spd LHD
        3-4 Audis in parts
        • meep
          • May 2005
          • 203
          And the answer is!!!!!
          *Heavy suspense and drum roll*
          Front prop shaft is bent
          • YELL MAN
            • Dec 2005
            • 541
            • Country: Shetland Islands
            Happened to me a couple o years ago too. But I didn't bent any shafts.
            1994 Indigo Blue S2 coupe
            1994 80 Avant 1.9 TDI
            2005 Yamaha Fazer 1000
            1953 AJS Model 18S
            • prosty
              • Jun 2005
              • 1114
              You mean the driveshaft? Easy fix man!
              2004 9-5 aero
              3-4 Audis in parts
              • meep
                • May 2005
                • 203
                No thats already replaced. I mean the prop when you turn it it isnt centered it almost touches the tunnel.
                • Fat Audi 80
                  • 10547
                  Wow! That is bent.
                  This is what happens when you go "playing"
                  Hope you get it all sorted out soon though.
                  Cheers,
                  Steve.
                  The Perfectionist
                  • meep
                    • May 2005
                    • 203
                    Talked to prop shaft specialist.
                    They said that with stock drive shafts and old original prop bearing theres no flex in the drive line. He suggested new stock prop and new bearing and then filling the rubber bit in the new bearing with a hard rubber compound to take out the flex of it. What do you guys think?
                    • meep
                      • May 2005
                      • 203
                      Solved was joint that bolts to gearbox that was totaly stiff. Glad i have another propshaft. Time to change the bearing on that one.
                      • s2driveruk
                        • 12696
                        hehe, nicely done I gave up heavy launches about 3 days after I bought the car and had given the clutch a hard time. Seems best to get it rolling, even just a touch then nail it
                        1992 3b S2 Coupe
                        • Alistair E
                          • 479
                          I am also suffering some loud vibration noises and a less loud knoking noise. Front wheel bearings have ben changed recently and it's a lot louder than the noise one of the bearings was making prior to change.
                          Had the front left wheel in the air spinning while on the axle stand to see if I could identify what it is. No joy so far. Will try and work my way around the car and check the others. The vibration noise is bad and is totally wheel speed related.
                          Any other suggestions? How loud is the prop bearing when it goes? It's really resonating through the car. Maybe it's a combination of prop bearing and a slightly bent prop?
                          Alistair
                          • Alistair E
                            • 479
                            Right, I've been out at lunchtime and had both front wheels up in the air one at a time. It would appear that I was wrong with the initial thought that the nearside was ok. It is much noisier from that side.
                            Can't see anything binding. Brakes have had the common problem of the groaning noise but this is much different.
                            It's strange that it only started after the tyres were changed on the front but I'm now on different wheels and tyres so it can't be them. Wondering if something was damaged when they were changing wheels but can't see what.
                            Again, any suggestions?
                            Alistair
                            • meep
                              • May 2005
                              • 203
                              Might be driveshaft joint? Does it get better or worse when you are turning?
