v8 diff swap, parts.. and torque settings
  • lind4hl
    • Jul 2008
    • 2465
    found an torsen now and will swap them over soon, started to look on parts to order i understand that i need this:
    1x N 905 144 01 flange gasket No more available! use tube sealant instead
    1x B 016 409 399 B o-ring seal (right side driveshaft flange) right side 45x60x8
    1x 017 525 400C o-ring seal (left side, bigger for v8 flange)
    10x bolts that holds the crown wheel to the diff ( i dont know if these are nessesary, but i bought them anyhow, maybe some lock-paste on them, feels better with new anyways..)
    also does anybody have some torque numbers on these parts??
  • caterpillar
    • 2480
    http://www.s2forum.com/forum/showthread.php?t=9680 ?????????????
    • lind4hl
      • Jul 2008
      • 2465
      no torque numbers are in that thread what i can see???
      • lind4hl
        • Jul 2008
        • 2465
        from the v8 i can find these o-ring seals:
        B 014 409 400 AA
        01E 409 400 40x52x9mm CBM/ CBN diff is this the one??
        • A80Avant
          • 10873
          • Country: Greece
          you do know that v8 rear diff, cant handle more than 450hp according to some people who tried it here on the forum, right?
          • lind4hl
            • Jul 2008
            • 2465
            yep, i will try it anyhow.. and no launch-control-banzai launches of course..
            • lind4hl
              • Jul 2008
              • 2465
              i ordered the parts today on V.A.G..
              i will post up an how to and part numbers etc later..
              but damn that o-ring seal from the v8 is expensive 50€
              no-one have torque settings for these parts, i forgot to ask that..
                I probably have the torques for ordinary rear diff - not V8 torsen specifically - but should be same... can you post a photo of exactly where you are talking about?
                • lind4hl
                  • Jul 2008
                  • 2465
                  torque numbers where the crown wheel sits on the diff
                  torquw numbers on the bolt that goes thru the drive-shaft flange in to the diff
                  torque numbers on the scover on the right hand side.
                  i think that was all i need..
                  also the big o-ring (171x3,5) is not more available, and im not buying the tube sealant for 50€ from vag... so i will have to dig out an o.ring or some sealant on some other palce
                  • madpugger
                    • Sep 2007
                    • 1901
                    If you have the sizes of the seals, just go to any bearing/seal place. Take an old one with you if you can, even of the incorrect size, it will help them find the correct type of seal for your application.
                    Le Mans 2012
                    Nurburgring 700
                    1995 S2 Avant
                    • lind4hl
                      • Jul 2008
                      • 2465
                      yeah i know, but since i want the parts when the diff comes i ordered it anyway, byt i will meausure it and put it up for other people
                      • lind4hl
                        • Jul 2008
                        • 2465
                        Paul: i would like to know the measurments on the backspacing (backslash?) on tje diff also, if you know what i mean..
                        • lind4hl
                          • Jul 2008
                          • 2465
                          did you find anything paul??
                          i should have done an write up today, but forgot the camera
                          Oem diff is out, only the crown-wheel to come loose.
                          • javispa
                            • Jul 2007
                            • 292
                            • Country: Spain
                            I was going to open a new thread but I have thought that it would be better to ask it here as it has relationship.
                            I have also been searching the forum and haven't found the answer. I imagine it will not be possible to do, but I just want to make sure.
                            Is there any change to install the whole Audi V8 rear "bridge" (I do not know the technical word in english) in a Coupe? I mean, the V8 diff, subframe, driveshafts, hubs, discs, rear brakes, shock arms, etc. The thing would be to take all the rear part from the V8 and install it on a S2 Coupe.
                            Although I am sure that it will be wider, I just want to make sure if it is possible.
                            Thanks to everybody.
                            Cheers .
                            Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
                              In a word. No! Totally different set-ups at the back
