I posted on the 'Short Shift Kt' but need some advise ASAP.
I Installed the shifter everything was going fine got the console back on, then realised that we had forgot to put the the shifter pivot sleeve on. So ripped everything back off.. tried to pull the shift fork back up so we could reconnect the shifter pivot. The DAMN shift fork broke . Now i need to know if this fork is a single part that can be replaced? Been having a look today and def need to remove the exhaust to get to it underneath.
On plus side, installed the HIDS and
