I Think My Clutch has just given up the Ghost
  • gunman
    • Jan 2009
    • 660
    Had the S2 for about a month now and all was going well up until about an hour ago. Took off in first and went to change up but no luck. I think the pressure plate may have given out. Cant now get the car into any gears while the engine is running. pressing the clutchpedal does little except make a slight whirring noise.
    Here's the story:
    A couple of weeks ago I notice while holding the clutch in there was a whirring noise (probs thrust bearing) and the clutch was very close to the floor. Akso under heavy acceleration, when you dip the clutch to change up there was a bit of a thump from it(hard to explain, I thought maybe a mount was on its way out).
    I have checked the fluid and it seems fine, no leaks from the slave or clutch master cyl.
    It does look like I'm gonna have to drop the gearbox out of this and change the clutch doesnt it. A bit skint too after just buying it was on my way home from buying 4 new tyres for it (can't complain, got 4 brand new mitchelins for £200 off a mate).
    Anyone advise where is best to buy a clutch?
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
  • gunman
    • Jan 2009
    • 660
    shoot me down guys but how bad a thing could this be:
    http://cgi.ebay.co.uk/AUDI-S2-2-2-TU...item3ca49cc313
    1996 Audi S6 Avant.
    • gunman
      • Jan 2009
      • 660
      BTW, I went back out to it and got the wife to push the clutch pedal, the flexi hose moves with the pedal and I can hear a clicking sound in the bellhousing so it really does look like somethings gone wrong with the pressure plate.
      1996 Audi S6 Avant.
      • Knight Rider S4
        • 3541
        No No and No...I had one on for 10minutes ...crap!! If you intend to keep the car standard /chipped K24 turbo buy OEM clutch /LUK
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Acidburn
          • 13459
          think knight rider s4 used something like this but not sure, if u can get one recommended by people on this forum save taking it out when it gives up again.
          I had something like this with mine, i managed to drive mine for 3 months with the clutch like that till it fully gave up.
          • gunman
            • Jan 2009
            • 660
            Maybe thats what's in it then.
            Me thinks the guy who sold it maybe knew it was on it's way out, just never noticed until I drove ita week or so. Ah well, do it right and it'll do for a while.
            1996 Audi S6 Avant.
            • K Simmonds
              • Dec 2007
              • 7632
              From the symptoms you describe it sounds like the one of the springs on the friction disc has broken and is locking the clutch, as you suspect it's fuked. Had the same thing with my Corrado G60, clutch felt odd for a few hundred miles then a bang and it locked up, no clutch what so ever, constant drive. Striped it to find all the springs from friction disc in pieces inside the flywheel/clutch assembly wedging the whole lot solid.
              Sachs clutches are very reliable, probably what I'd go for.
              1990 B3 2.0 80 quattro.
              1992 C4 2.8 Avant quattro
              1994 MTM RS2.
              1998 B5 TDI quattro Sport.
              2000 B5 TQS.
              • gunman
                • Jan 2009
                • 660
                euro car parts list the sachs clutch for around £140, I'll phone the local branch in the morning and see have they got one.
                cheers guys
                1996 Audi S6 Avant.
                • gunman
                  • Jan 2009
                  • 660
                  Now I'm confused. They list 2 clutch kits with different sized plates. which one does my car (95 6 speed aby avant)?
                  1996 Audi S6 Avant.
                  • Nuvo
                    • Nov 2003
                    • 3826
                    Aren't these essentially the same part? The only difference being the manufacturer (and the price of course).
                    • Nuvo
                      • Nov 2003
                      • 3826
                      My mistake, the diameters are different. Hmm.
                      • gunman
                        • Jan 2009
                        • 660
                        A local factors can get me a valeo kit for £170, phoned local euro pcar parts, they are quoting £205 for a sachs. need to order one of them today so any help would be mucho appreciated.
                        1996 Audi S6 Avant.
                        • GazzaG60
                          • 4133
                          get the sachs
                          • K Simmonds
                            • Dec 2007
                            • 7632
                            Yeah, for the sake of 30 quid I'd definitely go for the Sachs over a Valeo kit, especially if your planning on a bit more power in future.
                            1994 MTM RS2.
                            2000 B5 TQS.
                            • gunman
                              • Jan 2009
                              • 660
                              error
                              I agree, but what worries me is the 12mm less plate dia listed on the euro car parts website for the sachs clutch. Will it fit? What is the correct size? 228 or 240mm? Will they both fit?
                              1996 Audi S6 Avant.
