Oops, broken pins
  • goodall
    • Jul 2008
    • 810
    Oops, broken pins
    I dropped my 7a flywheel this evening and snapped of the two pins on the gearbox side. Are they required for the 7a ecu to work? I cant see how any the sensors would pick up a signal from these pins so guessing they dont do anything...
    So are they needed
  • terrybullwon
    • Mar 2006
    • 8782
    iirc they are balancing pins?
    Chef
    • Tonks4x4
      • Nov 2005
      • 3062
      No just the pin on the engine side of the flywheel and the teeth on the starter ring are the two reference points.
      Audi Nut!!!
      • AndyP
        • 6049
        The 2 long pins on the gearbox side are used for an old Audi diagnostic machine, not important, they ground mine off when I had the flywheel re-faced.
        • goodall
          • Jul 2008
          • 810
          good so nothing to worry about then thanks
          if hadent been so heavy wouldent have slip from my hand, makes me now want mount up on a lathe and remove half its bulk :mischeif:
