Rear left wheel related sound...
  • A80Avant
    • 10873
    • Country: Greece
    when i take light left turns i sometimes hear a repetative sound from the rear left side of the car. I have never heard of how a damaged wheel bearing sounds. Is it knock or something?
    This one sounds like there is something soft dull repetative noise, which resembles the sound that really worn pads do when you brake.
    It is within my plans to replace diff and transmittion oil and the propshaft had been renewed on lubricants 2 years ago.
    Rear driveshafts have never been tampered with though.
    What should i look for?
    thanks
  • K Simmonds
    • Dec 2007
    • 7632
    Wheel bearing, I'm 99.9% sure.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • A80Avant
      • 10873
      • Country: Greece
      aha
      so what am i looking for,and do i need to go to audi for them?
      • A80Avant
        • 10873
        • Country: Greece
        found at etka: 4D0 407 625 E
        do i need the rubber boots replaced if they are OK or can they be remounted ?
        • K Simmonds
          • Dec 2007
          • 7632
          Not sure on the best place to get them, probably TPS, do you mean the CV boot? if they look perished then now would be the perfect time to change them. Just a thought but check your wheel bolts are tight before you order any parts.
          1994 MTM RS2.
          2000 B5 TQS.
          • A80Avant
            • 10873
            • Country: Greece
            i found them from GSF for 11.50 so i ordered a pair. My CV boots are ok. i just thought whether these were actually something that needed replacing as well.
            my only other thought now is though the rear handbrake mechanism,which tends to crumble once tampered with.... and those are not cheap...
            meaning the caliper carriers: 8A0 615 411/412
              I would order an OEM bearing from Quattro Corner, those GSF ones have been known to fail in under 2 years
              • A80Avant
                • 10873
                • Country: Greece
                oh i see.
                so these arent OEM then?
                  Unfortunately they are not, I found one forum reference but I had heard this from my mate who works at GSF!
                  • A80Avant
                    • 10873
                    • Country: Greece
                    damn!
                    noted. i will cancel the order and get one sorted properly
                    cheers
