I have a lightened and zero balanced 3b flywheel that i have just picked up from my bead blasters.
It looks like new now but there is a little ware on the clutch side.
Is it worth skimming of .5mm or so to get a nice flush finish again?
Its being used with a custom made Spec unsprung friction plate and a uprated stage 3 pressure plate.
Will skimming ti throw out the balance or will ti be ok as the same surface arear will be removed all over the face? This will also move the pressure plate closer so it will not course clutch slip.
Or am I missing something, apart from a few brain cells
