ABS light on when diff lock is on
  • mayhemg77
    • Nov 2007
    • 106
    Hi Guys
    I recently replaced the leds in the diff lock switch, when i tried the switch yesterday the ABS light came on in the dash, and when i drove off it was "biting" the brakes, as ABS should, however, i didnt have my foot on the middle pedal!. The green light on the diff switch didnt go on either.
    Anyone have any idea whats going on?
    Rgrds
    Graeme
  • nesshead6
    • Apr 2009
    • 598
    I think the ABS light comes on in mine too, but I don't get a problem with the brakes. I'll have a look when I get home.
    • Acidburn
      • 13459
      the abs light should come on when the diff lock is engaged.
      • mayhemg77
        • Nov 2007
        • 106
        the abs light never used to come on, but the green light did, now it doesnt, ill double check led connections in the switch
        did concerned about the brakes pinching tho, i know thats not right.
        • mcandmar
          • Apr 2004
          • 5118
          The green light will only come on when the diff has successfully locked, normally you have to drive in a straight line for a few feet before it will lock in. ABS always cancels when the diff lock is engaged.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
            won't be the ABS triggering, probably just the rear wheels hopping becasue the diff was locked
            • madpugger
              • Sep 2007
              • 1901
              Agreed, you will be experiencing "wind up" and nothing to do with brakes. The ABS light should come on when diff is locked, or trying to lock.
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
              • mayhemg77
                • Nov 2007
                • 106
                ok, thanks guys for piece of mind, i thought things were going pear shaped
                rgrds
                graeme
