Thought I'd write a quick guide on how to do this after doing it this weekend with the help of lots of different threads on the forum. This is based on an ABY.
First of all lock the steering over hard right and put it in 6th gear. This makes access much easier.
Then jack up the n/s to get the nipple as high as possible.
Leaning behind radiator the bleed nipple can be found just behind the bolt shown in the attached picture on top of the slave (pic courtesy of another thread). You won't be able to see it but if you have a feel around you'll find a rubber dust cap that comes off with a small tweak with pliers.
Attach the gunsons Eezibleed to the brake fluid reservoir as per the instructions, the kit comes with the correct size cap btw.
You might want a container to catch the brake fluid as it pours out all over the wishbone and floor depending on what pressure you have the gunsons at, I used 20psi as suggested and it worked a treat.
You'll then need a DEEP 11mm socket and ratchet to undo the nipple which unscrews pretty easily, about 1/2 - 3/4 a turn and you should get a good flow of fluid.
I pumped the clutch pedal a few times to make sure all the air came out of the master cylinder while it was bleeding. Keep an eye on the fluid level of the gunsons as it drops pretty quickly. I put through about 2-3 litres just to be sure.
Access to the nipple is quite restricted
so getting a spanner in there isn't really an option, so you have to use the socket to do it up, it might be worth having some rag on hand to wipe fluid off the socket so you can get a better grip.
When you've bled enough fluid through, tighten the nipple put the dust cap back on. You should now have a nice light clutch pedal!
so getting a spanner in there isn't really an option, so you have to use the socket to do it up, it might be worth having some rag on hand to wipe fluid off the socket so you can get a better grip.When you've bled enough fluid through, tighten the nipple put the dust cap back on. You should now have a nice light clutch pedal!
