Flywheel pins
  • add
    replied
    thanks again for the replies
    picked it up this afternoon.....
    it appears the alignment pins got away unscathed
    replied
    Originally posted by add
    but i will still need to replace the three alignment pins....
    The PN for the 3 alignment pins (aka "dowel pin") is N 013 210 2
    These pins are common to many Audi flywheels, e.g. for the KV,NG,7A,3B,ABY,AAR,AAN and ADU engines with stock flywheels.
  • add
    replied
  • th.b.w.
    replied
    You don't need the 2 longer pins...
    I have remove them in my Fidanza wheel and it works great....
    Thomas
  • add
    replied
    ^it was the longer pins i wasn't sure about,forgot all about the others for aligning the clutch platei will be needing those then
    -Actually does any one know a part number for the three alignment pins?
    -do they have to be hardened or not?if they dont i could just make some...
  • th.b.w.
    replied
    There are two pins about 30mm > for checking the ign. time at , factory, but no need.
    The 3 pins ~10mm want fitt the clutchplate, these are needed !!!
    On the Engine side the 10mm pin is for ecu ign.time signal> must needed
    Thomas
  • add
    replied
    cheers guys
    that answers my question
  • Billman
    replied
    The are there to align the pressure plate to the bolts that securing them AFAIK.
  • AndyP
    replied
    There are 2off long pins on the friction side, these are not used. Ths sensors on the side of the bellhousing pick up on the short pin on the opposite side and the teeth for the starter motor.
  • add
    started a topic Flywheel pins
    Flywheel pins
    Right guys,in need of your expert knowledge.
    Basically my 7a flywheel is at the machine shop having a skim,they are taking the pins out of the friction side of the flywheel (obviously so they can skim it),my question is are
    these pins needed for anything,i swear i read somewhere that they weren't
    Are the cps/rpm signals taken from the teeth/pin on the engine side of the flywheel?
    If that makes any sense
    Just want to know if i need to replace them or not.
    TIA,Adam.
