Tonight the 20v cq decided to have a major burp, it has lost all of it's 5 forward gears.
Reverse works great, clutch is fine i have a decent pressure in the pedal. I can select a gear but just when the clutch starts to bite you get a horrid grinding sound like you get when you miss a gear and resonates / echo's a bit like if you have hit the prop shaft with a hammer.
The sound changes in pitch as well depending on which gear you rey to use, first is lower in tone with 5th being a higher.
No warning of any impending failure no whines moans or groans, smooth shifting box rear diff bush is a bit bump thump but then most are unless they have been changed.
All i did was to move off on a slight incline not even revving the nuts off it just really normal slow speed stuff.
Both AA guys hadn't seen or heard anything like this before. What the heck is going on????
Jim
Jim
