Banging and loss of power
  • Donsider
    • Dec 2009
    • 77
    Just spent a small fortune on my S2 with mountings,ball joints,tie rods,refurbed subframe,rear diff bracket all replaced.
    Went out for a thrash and the following happened.
    Floored the car and loads of banging from rear end and loss of power, if someone had been close behind me it would have been a rear ender.
    Now, this has only happened since getting the car back from the garage
    Took the car back and they said nothing wrong!
    Went out and wound the car up and again jumping about and loss of power!
    Any ideas before i go back and complain again.
    Cheers,Mike.
  • willg54
    • Jun 2009
    • 2055
    id say it sounds like a rear diff problem? I'd find out if they've done anything to the diff?
    1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
    1994 Audi 80 - 2.0 8v (slow but reliable!)
    • Tonks4x4
      • Nov 2005
      • 3062
      I would say it's a boost leak, I bet they have dislodged a pipe somewhere
      Audi Nut!!!
        Boost leak sounds like overboost protection
        • Acidburn
          • 13459
          agree with jamo and tonk's.
          • Donsider
            • Dec 2009
            • 77
            Much appreciated, i will get them to check.
            • Dpicariello
              • Mar 2006
              • 621
              Check that they're plumbed up the diff lock actuator properly. That uses boost pressure to actuate the difflock so if it's not be plumber right or at all then you'll have a reasonable boost leak which could cause over boost protection to kick in.
