SRE -707 pressure plate and suitable clutch disc for it, SRE says 500Nm hold, and as always with SRE most likely it will survive 600nm if not used for drag. Oh, and that is with organic plate 500Nm. With sinter disc somewhat more. If you go to sinter disc, order 707 (3B) pressure plate and disc for AAN (thickness differs 0,1mm but it's unsprung, and will last much better than spurung sinter disc)
All quattro products have been dermatologically tested, and are safe for daily use.
