6 Speed into an Ur Quattro
I have my Audi Driver article on the swap into a 1986 coupe quattro if it helps. A few differences if fitting to a Ur but you'll get the basic jist of the work involved. Send E-mail address in a PM if you want it.
so basically what needs to be done is..
notch engine mounts
use rs2 gearbox mounts
use the S4 gear linkage with ur-quattro gearstick and cage with S4 internals? I know it says on your thread S4 parts but are the S2 the same?
use 3B clutch and flywheel or 034 lightweight version and suitable clutch?
one drive needs a spacer and the other doesnt
oh and I had a good look at your build thread! and I got to say damn, well done!
seeing threads like that help me get my *** in gear and get mine done!
6 speed
Do have a DSY 6 speedbox in my urquattro, and use the stock mounts.
3B flywheel en custom linkage and driveshafts.Leave a comment:
Thanks guys! ill give that thread a good read tonight!, id like to start gathering pieces to get it fitted soon!Leave a comment:
The transmission tunnel does not need to be cut. You just use custom mounts and a spacer, along with a combination of urs4/s6 gear linkage and UR cage hybrid.
Not very specific I know, but there are quite a few cars with 6spd now, mine included, it uses an AAN engine.Leave a comment:
EFI express has mounts to put a 6 speed into an URQ. The swap is fairly easy once you have all the right parts. Basically you need the clutch flywheel, the said mounts, the linkage, and finally the right axles. The RHD passenger side shaft works, but the drivers does not. I ended up using a short RHD passenger side shaft on both sides, with a 29mm spacer taking up the difference in length.
Take a loook at hte link that Martin posted, as it is very helpful.
Any 6 speed is stronger than the quattro 016 box, regardless of the first gear width. The 016 boxes get weak at around 420wtq, and the second gear is the weak link. I have been running 530wtq through a narrow 01e for thousands of miles now, and it holds up to the abuse a lot better. The wide 6 speed is obviously the better option, but not nessisarily needed in the lightweight URQ.
FYI, don't touch a allroad 6 speed. You have the wrong rear diff gearing to make that work. You want to find a trans with either a 3.89 from the TDI for a couple of years, or do a 4.11 rear diff swap from a small chassis car, and then put in the regular 4.11 transLeave a comment:
The six speed is not as strong as the quattro box
If you switch your clutch and flywheel is all S2.
You need to bring over the linkage as well. This means adapting the tunnel
Early 6 speeds are weak. The later ones much better
If you want proper robust then an RS4 2.7T box can be made to fit or even an All Road if you can find oneLeave a comment:
So.. the ax has fallen and last November I was able to pick up not one, not two but three Ur-q for the price of one. Here is the original ad: "I have three Ur Qattros on the blocks... 1. 1981 Mars Red (yes an 81 from Europe) that is a rust free shell but has 90% of the parts brought in as a...
Hope this helpsLeave a comment:
Could anybody explain how to do this?
whats involved, what needs to be changed etc?
im fitting an aby engine, so this could be a good conversion to do at the same time!
ive read it gives you another few iches room at the front? and that its stronger then the standard 5 speed in the quattroTags: None
