6 speed linkage repair??
  • re2500
    • May 2007
    • 2185
    Does anybody know the dimensions for the ball and cup, such as the ball size. Nylon cup insert OD, stud size OD attached to the ball? We have a supplyer of spherical bearings we use where i work and have found some standard catalogue parts that look like they will work with very little modification!!
    "Difficult is worth doing"
    • Chris P
      • Dec 2004
      • 145
      I made one using a sperical bearing. Although i did fit it on and it did work, it was very tight as there is no play in spherical bearing like there is on a standard ball and socket linkage. So, like when you have it in neutral and normally it will wiggle side to side nicely, with the spherical bearing it was more rigid. I did end up using a standard one in the end but if i had spent more time setting it up i am sure it would work. I may try it again at some point. I have some pictures on my camera which i will load up tomorrow.
      • re2500
        • May 2007
        • 2185
        That would be helpful cheers bud
        Im going to take some Dimensions from my linkage tonight and contact a bearing manufacturere to look at getting some almost direct replacement ball cups made and get some prices at some point.
          Mine will spring to neutral as standard, but the spring needs to be stiffer. When I next have my gearbox off I'm planning to modify my detent springs as JHM / SpeedingG60 have done to overcome the inherant stiffness of the uniball
          • Chris P
            • Dec 2004
            • 145
            #20
            This was how i did mine.
            First unscrewed the ball of the end of the linkage arm.
            Found a spherical bearing that just fitted nicely into the cup of the main arm
            Then had the ball off the linkage arm machined down so it went into the spherical bearing but still leaving the allen head on the end to screwit to the linkage arm. Also had the end of the ball machined down so it would just sit on the lip of the bearing but still rotate within the casing of the bearing.
            Then cut a hole in the bottom of the cup on the main arm so i could get access to screw the new machined ball onto the arm.
            Then put it together.
            • re2500
              • May 2007
              • 2185
              Looks good mate!!
              Did you bond the new bearing into the cup?
              What stops the small linkage arm pushing through the bearing and further into the cup?
              Where did you get the bearing from and do you have any info on the size of it?
              Cheers Chris,
              James
              • Chris P
                • Dec 2004
                • 145
                #22
                The bearing was just a nice fit that it pushed into the cup. I then just had a couple of tack welds put at the top to stop it coming out.
                Nothing stops the arm pushing further into the bearing as i realised that this did not really matter that it could push in slightly. Once bolted to the gearbox it cannot push in that much anyway. Stopping it pulling out is the main one.
                The bearing i got from city seals and bearings. I need to find the receipt so i can get the code for it. I seem to remember it was about £40.
                • hiloran
                  • Mar 2010
                  • 121
                  What is the bearing size/type to be used in this mod?
                  • State'd RS2 Coupe
                    • 57
                    I've got this sitting in my garage waiting to get fitted...
                    http://store.034motorsport.com/shift...e-6-speed.html
                    If anyone has a source for the gaiter boot, or happens to have one, please let me know.
                    1990 Coupe Quattro, Full RS2 Conversion
                    http://www.europeancarweb.com/featur...rs2/index.html
                    2008 S4 Avant, Sprint Blue
                    • hiloran
                      • Mar 2010
                      • 121
                      Any marking on the bearing to buy one
