some CGR gearboxes are similar to the CRB gearbox ??
  • fluk3
    • Mar 2008
    • 146
    • Home: Denmark
    am I right ? are there some CGR gearboxes are similar to the CRB gearbox
    from mid 1994---> ??
    cheers christian bogh
  • Zoig
    • Sep 2008
    • 555
    Both are 01E boxes with same ratios, why is this important?
    • A80Avant
      • 10873
      • Country: Greece
      are all CGR having the strengthened 1st gear cog that the CRB have? I thought that was the main difference
        AFAIK the CRB had the wider first gear and flexible input shaft. The later CGR boxes shared these components I believe
        • fluk3
          • Mar 2008
          • 146
          • Home: Denmark
          it's because I'm about to buy a CGR gearbox from 1995 but how can I be sure that it is as strong as RS2 (CRB) gearbox
          maybe it is possible to check the number on it and that way see if it is weak or strong ?
          • Zoig
            • Sep 2008
            • 555
            You can look from the casing.
            Also here you can check if the mainshaft is flexible or not:
