I need to remove the slave cyl. From a type 85 Quattro. Think it the same for the S2, URs4. Could do with some how to do tips.
Manual says there is a pin that holds the slave cyl in place. I see on my car it is hollow and did some research on the outer dia of the pin so that using a drift punch, the pin can be knocked out. I see on the www that the nominal size is 6mm - any drift between about 4.5mm and 5.5mm will work. Can anybody confirm?
Secondly I thought to leave the hydraulic pipe work connected, so that to get the slave cyl out the gearbox, all I need to do is push on the clutch, instead on trying to lever the slave cyl out the gearbox. Am I bit worried as to whether the slave cyl will clear the gear selector that's just behind the slave cyl.
Thanks in anticipation.
