If you remove or cut the road speed signal wire to the rear diff controller, the rear diff will stay locked above 15 mph (25 kph). This is mostly a drag race modification because if you are NOT going in a straight line, the two rear axels should NOT be locked together. The question is, for those who have cut that wire (white with a blue stripe on a C4 UrS4 and 95 UrS6), at what speed is it safe to disengage the rear diff lock? (Normally this occurs automatically at 15 mph (25 kph) but with the wire cut, disengagement comes only via releasing the DIFF button).
