need to remove the gearbox shortly,the engine is already out.
with the engine out i can easily get to the driveshafts and bolts etc,but baring in mind i am doing all this on the floor whats best to get the box out now,i can get to the gearbox mounts easily enough and the prop bolts are all out (apart from 2 rounded ones on the rear diff end)?
is it best to jack it up or do it on ramps?i was thinking get one end on ramps and one end on axle stands? thanks for help chaps
