Is there an alternative or internal upgrade for the 01E box that are not dog gears?
Finding the stock box configuration is just not liking 1st to 2nd despite having a late model box with wider 1st with fresh synchros lightweight flywheel etc...
The gearshift on the later 01Es from the B6/B7 platform cars is far smoother, its like butter in comparison, but IIRC its not a straight swap. Pembo has a B7 RS4 box in his rally car, he might be able to help?
here is syncro 1-2 kit with different ratio's than 3.50/1.89. at least, the description reads syncro style engagement, and straight or helical. not positive though.
awhile back (couple years) i recall seeing SQS had syncro sets for 01E, as well as DOG but i dont see them offering anymore.
EPC- pasy-2001-HG3-UG 00 pic side 300-10 there i have alot of finals in the tranny...
i hope some understand the figs.. i cant make the pics showing here myself..
any luck with this??
i am wanting a replacement box to put in the ur(6 speed)as after 20 or so launches the front diff seems VERY noisey....or should i just rebuild it????
The noise will still be there unless you find out what is causing it. What happens with these boxes is that first gear gets destroyed with drag racing and lots of horsepower. We can do different ratios and stronger gears but they don't have to be dog engagement, they can be syncro mesh also.
