Oil cooling for gearbox?
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    Originally posted by Error404
    You maybe right, I have never seen one. I was told the DSY & EDU both have the internal pump & fittings for the cooler, maybe it is just the DSY
    i was checking up , seems both have it fitted but the pipes is blocked in EDU or am i mistaking?
    • V6quattro
      • Sep 2008
      • 949
      2 Photo's off my DSY gearbox. Only thing i needed to to was make a spacer for the shift-plate (i used a bolt ).
      • Jim_Coupe
        • May 2011
        • 78
        • Home: Sweden Current: Norway
        Ahh nice... Me want that piece of technological device !!
        Where do ppl get the linkage?
        It´s just a question of time..
        http://www.garaget.org/?car=287344
        • Audi_CQ
          • 940
          • Country: Norway
          Use S2 6 speed linkage if you already have it. Need one spacer on the plate on top of the box as mentioned earlier. DVG box from A8/S8 is also an option (I'm running one on my CQ) and old S4 V8's (code CMG?) also had oil pump in transmission.
          • Jim_Coupe
            • May 2011
            • 78
            #20
            Okey thanks sound nice.. now i just have to find a good one with low milage onit.
            • Billman
              • 4129
              #21
              I believe to read somewhere in the forum a comment from either Pasbogdan or Pirvu Eugen about modifying the 5 speed linkage to fit 6 speed but I am not sure. Does it ring a bell?
              Go Holset or Go RS4
