Part numbers oil plugs RS2
  • afen
    • Aug 2011
    • 112
    • Country: Norway
    I'm about to do an oil change on my transmission and rear diff, and I'm going to replace the oil plugs at the same time.
    The only part number I have found is 012 301 127 F, which is the diff drain plug. Can this plug replace all the plugs on both units?
    Originally posted by afen
    I'm about to do an oil change on my transmission and rear diff, and I'm going to replace the oil plugs at the same time. The only part number I have found is 012 301 127 F, which is the diff drain plug. Can this plug replace all the plugs on both units?
    Transmission and centre diff both use N 10037103 which is an M22 x 1.5 plug
    012301127F is an M24 x 1.5 plug.
    • afen
      • Aug 2011
      • 112
      • Country: Norway
      Thank you for your reply. I found a website with the family album, and it lists the M24 plug. Link: http://nig.gr/eaa
      • yodasfro
        • Apr 2006
        • 129
        The 01E use the smaller plugs N10037106 but the rear diff still use the larger plugs WHT001937 you can see the differences if you google the #'s The RS2 might use the smaller plugs on the rear diff too?
        Austin
        1992 urs4 1991 200 20v avant 1990 90q 20v
          Austin: Your N 10037106 doesn't seem to be a valid PN.
          Here are some 01E plug PNs (Items 9, 26 and 27)
          • afen
            • Aug 2011
            • 112
            • Country: Norway
            Thank you for your help!
            This is what we've collected so far:
            Code:
            Gearbox filler plug:     N 100 371 03  (M22x1,5)
            Gearbox drain plug:      N 100 371 03  (M22x1,5)
            Centre diff drain plug:  N 100 371 03  (M22x1,5)
            Rear diff drain plug:    012 301 127 F (M24x1,5)
            The only thing I can't find in this crappy online ETKA is the rear diff filler plug, but I believe it's the same as the drain plug. Can anyone confirm?
            • yodasfro
              • Apr 2006
              • 129
              That's funny because when I search N10037103 it comes up as not valid on ECS and supersedes to the new # at other places. I did some digging and the #'s I posted are the correct new superseded pn#s for the plugs.
              Austin
                I guess my good friend Kate is getting a bit old. However, when searching for something like N10037103 with Kate, she likes to have two (2) spaces between the "N" and the number, i.e. N<sp><sp>10037103. N10037106 still doesn't work for me. However when I put N100371103 into GVAP, I got this:
                http://genuineaudiparts.com/parts/in...&siteid=214407
                You win.
