Removal of rear outer CV joint (avant/sedan)
  • Kroegarn
    • 92
    I´m in the process of changing the outer CV joint boot at the rear on my S2 avant. Could not see any snap ring and tried the "bolt trick" and it was a bit of resistance and finally it gave in, but what happened was that there WAS a snap ring and I torn the CV joint into pieces
    Luckily I had a set of rear drive shafts from a S4 (C4) with same type of outer CV joints. BUT I just can not get that annoying little snap ring to surrender.... using screw drivers, pliers and what not
    What is the correct AND time saving procedure for removing the rear CV joint?
    /Mike
    S2 RS Avant@355hp "For sale"
    A4 Avant TDIq@170hp
    Datsun 240Z@550hp
    BMW M3 race car@321hp
    Garage
  • sam80quattro
    • Oct 2006
    • 1496
    smack it off with a hammer... seriously
    • andy10v
      • 5996
      If I have navigated correctly then this
      Sold ABY-stock
      • Kroegarn
        • 92
        Tnx for that link... then I´m at least trying to do it correct... but f**k me how time consuming and fiddling to get that little circlip to not stick on somewhere around the driveshaft groove.
        Will drop it off at the local mechanic today, just to keep my sanity
        /Mike
        A4 Avant TDIq@170hp
        Datsun 240Z@550hp
        Garage
