Clutch Trouble, Again
  • 94S2Sedan
    • Jul 2012
    • 77
    • Home: United States Current: Brazil
    Cheers guys,
    I'm having some clutch trouble for the second time in two months.
    The first time it was a leaky salve cylinder, witch was a massive pain in the ***. I live in Brazil and S2 parts are pretty rare. I ordered the part online and 2 weeks later it arrived.
    This time the symptoms are pretty much the same.
    The clutch pedal is sticking, but it dosent seem to be leaking fluid anywhere.
    I think it might be air in the system, but it makes me think if it is just air how did it get in?
    everything was working fine until 3 days ago.
    Since the car is my daily driver i depend on it to get to class and work, i would really appreciate it if someone could tell me how to bleed the clutch without using a "ezbleed". I really need to do this today so any advice is much appreciated !
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Clutch pedal sticking = Master cylinder IIRC
    1996 S2 ABY Silver
    • 94S2Sedan
      • Jul 2012
      • 77
      But its not leaking...
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        I don't think it has to leak necessarily, it could be it's not holding pressure, maybe an internal problem..
        1996 S2 ABY Silver
          Clutch Master and Slave Replacement info
          The common wisdom about replacing clutch master and slaves is IF you only do one, the other one will fail very shortly afterwards. Best to do both at the same time.
          Here is a photo of a new Sachs Clutch Master Cylinder:
          Photo Courtesy of Fred Munro
          Here is a photo of the clutch slave cylinder from the transmission side:
          Photo Courtesy of Jerry Scott
          Many people recommend replacing both the clutch master and slave cylinders when replacing the clutch. Fred Munro did a great write-up on replacing the clutch master cylinder available HERE. Here is an UrS4 write-up by Brian C. regarding Clutch Slave Cylinder Replacement For a complete home garage-based clutch replacement procedure go HERE YMMV.
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            Lucky he didn't do the master first then, I've heard slave is a PITA
            Hope mine doesn't go any time soon
            1996 S2 ABY Silver
            • 94S2Sedan
              • Jul 2012
              • 77
              Thanks guys, i bled the clutch but its still sticking.... guess its the master cylinder.
              I appreciate the help!
              • rynaqui
                • Mar 2012
                • 2752
                • Country: Malta
                Good luck
                Should be an easy replacement
                1996 S2 ABY Silver
                • 94S2Sedan
                  • Jul 2012
                  • 77
                  Here is the situation, the clutch master cylinder is pretty hard to find here in Brazil. But VW of Brazil came out with the Gol GTI 16V in 1998 that uses the same gear box as the S2 but in a Front wheel drive layout. The Gear Boxes where imported from Germany and they use the same Slave and master cylinder as the S2.
                  I called a couple VW Dealers in my area and they quoted me 2,000 Reais which is 650 GBP and they don't have it in stock, they would have to order the part from Germany and would take about 30 days to arrive.
                  I went online and found this, http://produto.mercadolivre.com.br/M...6v-audi-90-_JM
                  The seller is claiming it is a OEM replacement part.
                  WOULD THIS BE A BOLT ON REPLACEMENT?
