Torx bit size for rear differential mount bracket.
  • Canadian RS2
    • Oct 2009
    • 145
    Anyone know the size of the torx bit that is needed to remove the bracket that holds the rear diff mount on the RS2? Biggest I had was a T40 but it was too small.
    Dave
    Originally posted by Canadian RS2
    Anyone know the size of the torx bit that is needed to remove the bracket that holds the rear diff mount on the RS2? Biggest I had was a T40 but it was too small. Thanks Dave
    Hmm.... my good friend Kate says "allen key head bolt (combi) M10 x 45 Z1" (not sure what Z1 means), PN N 90285102.
    • Canadian RS2
      • Oct 2009
      • 145
      Hey Dave,
      The bolts for the actual diff mount are a hex bolt but the bracket that holds the mount has bolts that use a torx head. Is that part you gave me for the mount or the bracket?
      Dave
      • andy10v
        • 5996
        Which bolts?
        Sold ABY-stock
          Hey Dave, The bolts for the actual diff mount are a hex bolt but the bracket that holds the mount has bolts that use a torx head. Is that part you gave me for the mount or the bracket? Dave
          The PN I found was for the Item 10 bolts in the diagram Andy P posted:
          • Canadian RS2
            • Oct 2009
            • 145
            The bolts I'm trying to sort out are No's 4 & 15. 10 and 12 are defintely Hex bolts. 4 and 15 are Torx.
            Dave
              The bolts I'm trying to sort out are No's 4 & 15. 10 and 12 are defintely Hex bolts. 4 and 15 are Torx. Dave
              My good friend Kate, to whom I once introduced you to at "party", says that No. 4 is a "bolt, hex head, with pin, M12 x 15. x 118", PN N 90524301. She also tells me that No. 15 is an "allen key head bolt (combi), EM8 x 52-V", PN N 90530601.
              Sorry. I am not finding what you want, just what she tells me. Hopefully, some an RS2 owner will chime in soon.
              • Canadian RS2
                • Oct 2009
                • 145
                Dave
                Looks like I answered my own question. The bolt requires a T45 Torx bit.
