Hi guys,
Yesterday I experienced weird clutch actions..
I depressed and released the clutch pedal, Only to realize that the clutch pedal got stuck half way up. It required a slight touch with my foot under the pedal, then the pedal sprang back to its normal position.
I am cautious to use the term "stuck", because although the pedal is stuck in half way position, I didn't feel any notches. It seemed like the pedal stopped due to friction in the particular spot along the travel path of the pedal.
Now it went back to normal, but I am curious what to look for.. I crawled in the footwell and took a look, but I didn't find anything abnormal. I noticed that there are two clutch return springs attached to the pedal. Maybe one of them is to blame?
