need a low offset 5 lug hub
  • my2000apb
    • Jul 2010
    • 637
    ive made up some kingpin/sphericals to replace the outer balljoints, but I have a clearance issue.
    they are very tight to my machined urS hubs In b3 front knuckles
    so basically I need a hub that sits as far outboard as possible, s2 coupe, avant? what has the lowest offset?
    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
  • quattro84
    • Mar 2006
    • 947
    Rears from a typ44 200 / 100 S4/S6 IIRC have the lowest offset, think that gives you 10mm more space.
    Can be bought here: http://homepage.internet.lu/customau...100_200_v8.htm
    Have a set of those floating around, can make measurements if required
    • my2000apb
      • Jul 2010
      • 637
      so people machine these for b3 knuckles, are they taking the ~8mm of material off for proper hub to bearing interface, of for offset change for brakes? or is it for cv splines to hub splines engagement?
      I have made up a spherical/kingpin to replace the outer balljoints, and need a bit more clearance for the weld cup to be welded to custom c-arm
      • caterpillar
        • 2480
        use a brake disk whith lower hatheigt.... and make another brake sadel/ adapter....... some of the senterhubbs are different... audi 90 (20v) and s2 does have +17 +17mm ofset...
        or se about the other vw versons,, eurovan or so...audi 100 or c4---
        • my2000apb
          • Jul 2010
          • 637
          the current discs are 320mm b8 a4q fronts, they are pretty low offset
          know of a specific rotor with less offset?
          • caterpillar
            • 2480
            seen in some katalog for disks and brakepads....?? they are listed in big nrs... 5x112.... some audi, some vw, some fords, and mercedes use them...
            • caterpillar
              • 2480
              http://www.brembo.com/en/Van/Replace...Cataloghi.aspx fx
              • sam80quattro
                • Oct 2006
                • 1496
                dont some a8's have a spacer that sits between the disc and hub? i seem to remember it from the many brake porn threads from the past..
                • terrybullwon
                  • Mar 2006
                  • 8782
                  They don't look very long king pins, are they about 40mm bearing cup face to bottom of hub?
                  Chef
                  • my2000apb
                    • Jul 2010
                    • 637
                    they aren't too long, im in the midst of building longer c-arms, with relocated pickup points on the subframe, so I don't need to get back all my geometry just at the pin
                    hmmmm that had crossed my mind, is that sketchy?
                    • Bowie69
                      • Nov 2013
                      • 2676
                      No more sketchy than running wheel spacers, and plenty of people do that round here.
                        Why not just use rotors with low offset bells to move the rotor out axially
                        • my2000apb
                          • Jul 2010
                          • 637
                          hahaha yeah that's kinda where I was going, dang project outta hand ahahah
                          I like that option more than "spacing"
                          know of a place where I can get 320mm x 30mm rotor rings?
                            You can get them AP do 320x30.
                            320x28 or 320x32 are more common sizes
                            Looks like they are available stateside cheaper though
                            THESE ARE STILL FOR SALE---NOW $150 PLUS SHIPPING---(UPDATED THIS POST TODAY 7/18/11)--I CAN ALSO BE REACHED AT 773-592-1515 Hi, up for sale is this set of high performance brake rotors by Racing Brake. These fit various Audi models. Racing Brake produces some of the finest brake rotors money...
                            • my2000apb
                              • Jul 2010
                              • 637
                              hmmmmm
                              soo many options
                              might just have to draw up some hats, seems like the easier way to do it
