80 quattro 2.6 rear diff mount ?
  • R5T
    • Jul 2012
    • 250
    Evening guys
    My rear diff is jumping about like a **** in a sock, every time I come off or on the throttle there is a half a second delay and the rear diff jolts up and smacks the underside of the car.
    I swapped out the diff mount for another use one that I believed to be in better condition, for the first few days it was better but gradually went back to how it was before.
    To save any confusion this is the mount in talking about :
    Yesterday I filled the original one up with epoxy and fitted it, I'm getting vibrations like a solid mount but it's the same if not a bit worse in terms of the diff jumping up.
    Is there any other mounts I can check/replace as audi want £120 for the one above.
    Also .. It's becoming increasingly clonky changing gear (especially from first to second).
    The car is a b4 80 saloon 2.6 Quattro, please note for the relevance of the thread that it is currently converted to RWD, the centre diff is welded.
    Sam
    93' Audi 80 2.6 Quattro
    93' Audi Coupe 2.6E Auto
    90' Audi Coupe 2.3e 10v
    95' VW Polo 1.0 ...
  • s2driveruk
    • 12696
    i'd check your cv joints for rotational wear, discovered my nearside rear was toast over the weekend, marked reduction in driveline shunt taking up drive and off throttle too following replacement
    1992 3b S2 Coupe
    • R5T
      • Jul 2012
      • 250
      Can totally understand where your coming from, but I've actually witnessed the diff jumping, I jacked the car up on the back and drove it in gear, came up the the biting point etc .. Every time you hit the biting point the diff is moving a good 1-2 inches.
      Sam
      95' VW Polo 1.0 ...
      • Sleeper_Avant
        • 2372
        the inner CVs wear and makes the diff jump
        i sent you an Email Sam, please reply
        • R5T
          • Jul 2012
          • 250
          Have replied Shaun, sorry once again !
          What's the easiest way to upload a vid on here ? I'll show you exactly what it's doing.
          How does the cv's wearing have an effect on the front of the diff ?
          I don't really understand :/
          Sam
          95' VW Polo 1.0 ...
          • Sleeper_Avant
            • 2372
            the balls on the Inner CV`s wear and they jump out of the holes they are seated in causing it to lock up and "jump"
            unbolt 1 rear shaft at a time and with the diff locked see if it stops doing it
            incidently,
            i bet its the prop!! same scenario, same issue and if youve just been ****ing about with it chancing bits over it may well be that!!
            • R5T
              • Jul 2012
              • 250
              Still can't locate anything, it's getting worse, and I'm sure there is something that is actually loose underneathe, even with the clutch dipped just rolling, if I hit a slight bump there is a metallic "cling cling" ..
              How much rotational slam should there be in a half shaft ? And the prop ?
              Sam
              95' VW Polo 1.0 ...
              • Mackers
                • Jun 2013
                • 20
                • Home: Wales Current: France
                Diff backlash?
                • andy10v
                  • 5996
                  There are two bushes (No. 6 in the diagram) at the back as well, also check the rear carrier is not cracked.
                  Sold ABY-stock
                  • R5T
                    • Jul 2012
                    • 250
                    Right, just had ANOTHER look underneathe, if you lurch on the bit in point it is definitely the front of the diff that is moving, audi want £120 for the mount as it's the bracket aswell etc, has anyone got one lying around that is in good order that I could try ? Or is there a replacement for cheaper
                    Sam
                    95' VW Polo 1.0 ...
                    • Sleeper_Avant
                      • 2372
                      A4 Quattro is the same
                      • Sleeper_Avant
                        • 2372
                        Pity your so damn far away or id come and have a look at it
                        • R5T
                          • Jul 2012
                          • 250
                          Hmm .. I'll look into an a4 one ASAP ..
                          Here is a link to a vid of what it's doing :
                          Sam
                          95' VW Polo 1.0 ...
                          • Sleeper_Avant
                            • 2372
                            100% something mechanical has failed
                            the bush is doing its job perfectly!
                            • Sleeper_Avant
                              • 2372
                              with the engine off and car on axle stands,
                              try it in first gear (engine off obviously)
                              turn/rock the rear wheel left to right and have someone check to see where the slip/knock is coming from,
                              i bet its the prop to diff joint
