Universal CV boot
  • Rikki Kitto
    • Feb 2010
    • 6276
    Universal CV boot
    Anyone had experiance with this type of boot, it is fitted with a hydraulic tool that stretches the boot over the cv joint for ease of fitting.
  • quattrostyle
    • Oct 2006
    • 6229
    The one I've used did fit but it was hard to get clamp onto the CV joint side as the hose kept slipping off.
    • Rikki Kitto
      • Feb 2010
      • 6276
      What was the quality of the boot like over time any ideas
      • irishs2
        • Apr 2009
        • 2455
        Same here. Tried fitting a universal boot to a cordoba cv. It would not stay on the outer cv side.
        Eric
        95 S2 Avant under rebuild.
        • Rikki Kitto
          • Feb 2010
          • 6276
          Might be a waste of time then
          • Monkeymagic
            • Mar 2012
            • 3419
            They are awful and the rubber perishes very quickly.
            • Rikki Kitto
              • Feb 2010
              • 6276
              Whats the best type guys, TPS want £40
              • mike74
                • Apr 2014
                • 615
                i got one from quattro corner as a kit with boot, grease, clips & bolt (outer cv joint) for about £16
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                    I've just got a new Spidan CV boot kit - p/n 26094. It comes with an OE quality GKN boot - £14.99 delivered
                    http://www.ebay.co.uk/itm/3312414225...84.m1497.l2649
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Got one off Quatrro corner in the end £23 seems fine GKN now fitted
