need to shorten drive shaft
  • A1quattro
    • Jul 2006
    • 789
    i need 10mm removed from n/s/f ur i drive shaft for the rally car [01e box fitted] . can anyone reccomend a good company or person the uk that does this mod . ive spoken to reco prop and they want £200 incl postage , which i beleave is excessive just to cut in middle ,remove 10mm and rejoin
    Don't think you can just cut & weld them, they need to be heat treated, straightened, balanced etc.
    Given the nature of your build I would get a bespoke shaft made.
    • A1quattro
      • Jul 2006
      • 789
      good point . i have since spoken to a company called berrisford , they can make a new shaft £160 + vat so i think i will go for that
      • jsws3
        • Apr 2012
        • 1174
        Talk to biturbo on the forum he can get them made cheaper then £160 + vat
        • Jenks
          • 261
          Put the relevant dimensions (of the bare shaft) up on here and CA and see if someone can match the size and fitment you need.
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            i have a b2 coupe quattro with 01e cbl box and have self shortened the right driveshaft
            i cut the shaft in the middle and make it on the correct length
            The shaft is hollow inside
            i made a iron bar 0.1mm thicker than the hole inside(about 30 cm long) and press(with big force) it in the both shafts and leave a gap in the middle of 1 cm for welding
            than i check the shaft for sling but it was okay
            after welding i drilled a hole on both sides and put a steel bar in from 12 mm a little to short so i could close the end by welding
            on the end i machinend the shaft so it look like one piece
            up to now, the shaft remained standing
            TWINCHARGED power,zero lag
            AEM W/M injection
            • 220bhp
              • 2578
              • Home: United Kingdom
              I could be Wrong hear, but I know from experience that the drivers side and the of side ,are different lengths.
              • A1quattro
                • Jul 2006
                • 789
                yes they are different lengths ,its the near side [left ] front that i have a problem with im pretty sure with the 016 gearbox the diff is on the opposite side of gearbox compared to 01e so i beleave we switched the shafts left to right when we fitted 01e box , its been fine for years but the the n/s has always been 10mm apprx to long meaning we have always had to run with more camber on that side
                • G60Rallye
                  • Dec 2006
                  • 1321
                  Run a shorter shaft from the other side with an alloy spacer between the gearbox cup and the CV joint. Means you need to carry less spares as well as the shafts are the same.
                  • my2000apb
                    • Jul 2010
                    • 637
                    YES!!! couldn't agree more!
                    for my build im making my axles all the same length and running spacers
                    carry just a few spares that work for all corners
                    BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
                    DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
                    • malncol
                      • Mar 2012
                      • 288
                      • Country: Australia
                      while your going convert to 130mm pcd A6 shafts ( stronger again)
                      thanks
                      mal
