ABC solid flywheel conversion ?
  • R5T
    • Jul 2012
    • 250
    Evening all, I know I've already got a mystery thread going below in this section, but wanted to start a separate thread for this.
    Reading through service history, my car has never had a clutch, and therefore id imagine the dual mass hasn't been replaced either.
    With my ongoing diff/prop/gearbox "clonk" I'm getting ever closer to swapping the boxes and doing the clutch as I have a spare 01E.
    Firstly, is there a solid single mass that would fit the abc ? I've heard of the TDI flywheels fitting with shorter bolts ? And if so what size clutch will I need ?
    Secondly, what would people suggest as a budget performance clutch ? I'm not looking for 6puc paddle clutches or anything, just a decent and fairly well priced uprated clutch ?
    Any help really appreciated,
    Sam
    93' Audi 80 2.6 Quattro
    93' Audi Coupe 2.6E Auto
    90' Audi Coupe 2.3e 10v
    95' VW Polo 1.0 ...
  • vag_nutter
    • Sep 2009
    • 164
    • Country: New Zealand
    You can use an 01a 5cyl flywheel on the v6
    • R5T
      • Jul 2012
      • 250
      Will I still be able to use a V6 clutch ? Or will I need a 5pot one ?
      95' VW Polo 1.0 ...
      • vag_nutter
        • Sep 2009
        • 164
        You will need to use the 5cyl one as the v6 one is for a dual mass flywheel. A 7a clutch will be fine
        • R5T
          • Jul 2012
          • 250
          No worries, thanks for the reply, and idea on rough price for the conversion ?
          95' VW Polo 1.0 ...
          • R5T
            • Jul 2012
            • 250
            Is there anything else I will need for this ? Shorter flywheel bolts ? Different pilot bearing ? Different release bearing ? ... I will be looking at doing this very soon and would like to get the ball rolling and price up
            Sam
            95' VW Polo 1.0 ...
            • vag_nutter
              • Sep 2009
              • 164
              Sam
              Yes you will need the bolts to suite the flywheel, pilot bearing is the same as is the release bearing, although you will want to fit a new release bearing
