Hi, i bought a S2 avant on friday and noticed that it is difficult to to select 1st, 2nd and reverse. So i decided to strip the shifter down this morning and i noticed that the shifter ball was worn. I have greased and adjusted it which has helped but i will need a new shifer ball bush. I have looked round and can find any aftermarket bushes. Am i going to need to get a new one form audi? It is 5 and 31 in the image below.
s2 avant worn shifter ball
Aud Tradition it's the place to ring.
https://trshop.audi.de/konakart/Sele...ING&model=0001
Changed that housing on my RS2 a month ago the original waas completely nackered.
The #5 does'nt need to be changed.
Get yourself from the dealer (they're still available) the # 32 ring
And make yourself with some heavyduty rubber the two #11 sliders I used the rubber used for working bench covers on mine.
Mind when you do the dissasembly the springs and pins that are holding together lever and bush... They tend to spiring around..... Easy to loose them...
I broke mine last weekend the same way, reverse and 1st were almost impossible to get into. The problem is almost certainly part 31, the plastic ball housing is suspended in the metal frame by a ring of rubber, and in my case the rubber had torn half way around so the ball housing was flopping around in there.
I managed to rebuild the shifter using a spare base from a 5 speed, its tighter now that its ever beenAttached Files91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
