AAN flywheel
    No that's what total job will cost you to do it all properly, assuming most of the work is DIY.
    • HMS-S6
      • Jan 2010
      • 1164
      Pressing the clutch on a dual mass flywheel car can alter noise/vibration. I assume due to the slight load change etc. I ecoeriance this on other cars quite often.
      With regard to the job. I've just changed my clutch, flywheel and box and to be honest wasn't nearly as bad as I expected. Quite enjoyed it actually.
      • HMS-S6
        • Jan 2010
        • 1164
        Just read it all properly. If you're looking to cut costs I would stick a known good engine in it and perhaps shelve your motor as a project for the future!
