Right ABY/ADU Clutch?
  • jubjub
    • Nov 2003
    • 1239
    Seems cheap? Is it the correct part...?
    As far as I know, the correct PNs are:
    077141117L for the 240 mm pressure plate and 034141033A for the 240 mm clutch disc.
    I don't think that advert is the one you are looking for.
    • jubjub
      • Nov 2003
      • 1239
      Thanks. Will look for alternatives.
      • AndyP
        • 6049
        http://www.eurocarparts.com/ecp/c/Au...c328ec3&000069
        Looks like that is from a 1.9TDi
        http://e-katalog.intercars.com.pl/#/...yciskowym.html
        Sachs don't list a std clutch for the ABY/ADU anymore, only the Performance clutch
          The reason that I kind of know that clutch is because my ABH in my 94 V8 S4 avant uses the same clutch kit as the ABY S2 and ADU RS2. I bought a Sachs kit out of Germany in Dec. 2013 (say 15 months ago). It was a Sachs Kupplungssatz 3000 951 053.
          I just searched on "Sachs Kupplungssatz 3000 951 053" and got several hits out of Germany. No photos in any of the adverts, unfortunately. The pressure plate is not "normal" because the flywheels in question are like dog "dishes".
          Here are a couple of photos. The proper one is on the left, the normal and wrong one is the red one on the right.
