Rear diff drain plug
  • martinjs
    • 3205
    Does anyone know what the part number is for this?
    IS there a washer of some sort also?
    Those of you with etka, is it number 4 or 14?
    really need to get one ordered today.
    thanks
    martin
  • s2avant
    • 2426
    It is number 4. Only listed on later cars for some reason!!
    012 301 127 F Retails @ £3.93 + VAT each. I can do them at £2.50+VAT each. It's the same plug for the filling and on the gearbox.
    VAG are showing 19 in stock. I've ordered 8 to bring to the garage meet in case anyone needs them. Don't know what day I'll be down yet though.
    Ben
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      Don't know how in other countries, but when I was trying to order the plugs from local VAG dealer, they brought plugs correctly sized but with some weird shape socked which was not usual hex socket.
      Lucky me, they took all four plugs back, but said, that the ones with hex socket are no longer supplied.
      Socket looks like torx socket but with full center. Don't know how to describe, but the wrench which is used to turn them costs a lot.
      Sau
      P.S. Managed to buy plugs from scrapyard - golf II gearbox plugs fitted just fine .
      • martinjs
        • 3205
        Ok thanks.
        Ive ordered two anyway, dunno exactly what time i'll be on the ramp at the garage.
        • blu_s2
          • 392
          Originally posted by martinjs
          Ok thanks.
          I'm hoping mine will be on my doorstep when I get home tonight. I have a funny feeling they will be the torx head type which may cause me a problem at Baschurch.
          Jim
          • s2avant
            • 2426
            The ones I've got in are the security torx type things instead of the old style hex head. I'll see If I can get a tool sorted out for them.
            Ben
              • 12431
              the garage has suitable TORX tool for doing the drain plugs.
              • blu_s2
                • 392
                Originally posted by Greg_S
                the garage has suitable TORX tool for doing the drain plugs. Greg
                Jim
                • s2avant
                  • 2426
                  I'll have a couple of the sockets with me as well just in case.
                  Ben
                  • Fat Audi 80
                    • 10547
                    You can buy the security torx drivers through RS components and should be able to get them from good fastener suppliers...
                    Cheers,
                    S
                    The Perfectionist
                      Do you need to use new filler plugs when you do this job?
                      Going to be using airtools with 17mm bit so dont reckon have any problems getting the plug out.
                      • audiman
                        • 4827
                        LOL, you will struggle to get air tools in there unless diff is pulled out. I had to do this when swapping my diff. And luckily it didnt do too much damage to the hex.
                        Tom C - www.rcmr.co.uk
                        Audi UR Quattro
                        Audi 100 C3 2.0 5 cyl 115ps
                        Audi B5 RS4 645ps 911nm
                          From what I've seen its the drain plug which gets most filled with road grime... The right Torx tool in steady hands with a long bar is all that is required in my experience to remove these boogers. But yes - remove the filler plug *BEFORE* the drain !
                          Paul
                            Removing the fillers wasn't a problem, but the drain plugs i would destroy if i got it off so i need 2 new ones.
                            On my car the bolts were a 10mm Hex not 17mm as stated.
                            Is there an alternative drain plug which is hex that can be bought?
                            I heard a rumour one from a Golf MK II?
                            • audiman
                              • 4827
                              Im sure all the S2's i have serviced have 17mm bungs, but your car is a late one, so they may have changed.
                              Audi UR Quattro
