First and second gear to hard
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    This started 2-3 month ago,but it wasn't offter,only after hard drive,and after a day or two all back to normal.
    But now,its insanly hard to put the car in first,almost like mission imposible,second is also very hard,but not like first?
    If i hit the first,when i change gear to second,if i dont do it very sloowww it grinds a bit?
    I also changed gearbox fluid with shell 75w90 but no luck
    Are my sinchrons of first and second dead?Or is something else?
  • RoadKill
    • Dec 2004
    • 567
    i would make sure the fluid is still full , is there much play in the stick the ball can fall apart
    service tec @ East Kent Audi
    S2 ABY
    B8.5 A4
    • Majorcina
      • Jun 2013
      • 1334
      That happend even before changing oil,after changing it it is the same.
      • diesel des
        • 3896
        The first to second selector gauls up and causes this. There is a new uprated part that can be used. Gearbox rebuild time.
        • Majorcina
          • Jun 2013
          • 1334
          Any link to those parts?
          • diesel des
            • 3896
            Jh motorsport
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              Does it so happen with the engine off?if not you can rule out the clutch dragging first.if the symptom is still exist,
              I'm doubt you have worn syncronizer rings.Time for a rebuild.Not fun job.You need a puller and hydraulic presser
              To pull some gears off the shaft.
              one of a few I5 from Asia.
              • Majorcina
                • Jun 2013
                • 1334
                Same thing happens when car is running and when its not.
