What gearbox?
  • jogi730
    • 2335
    What gearbox?
    ok, some on here know my car now. I want to extract more out of what I have got without further serious mods (for time-being at least ). However, although always realised had short gears, was under the impression I was running a WR box and diffs, but at recent RR discovered that in fact am still running standard 90 quattro g/b and diffs (4.11). Not only does this mean I cannot achieve 60 in second, but also at 80mph the engines is running at 4000rpm. As the turbo spools up at about 2500, this means I am always running boost and not vacuum and hence really low mpg.
    Would prefer to keep 5 speed box, but what are my options? WHat g/b and what diffs?
    Can one change gearing in box and if so to what - bearing in mind have fair amount of power and torque?
    Many thanks in advance.
    Chris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
  • Baldy
    • 469
    • Home: Sikkim Current: British Antarctic Territory
    u can always try the urq g/b and diff they should bolt straight in just the driveshafts n flywheel may need changin
    if you go for 1 from an MB engine or RR u get torsen diff too
    HTH
    Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
    0-60 4.9
    1/4mile 13.5
    • jogi730
      • 2335
      Also is it good to change to Torsen diffs or better to stay away from it?
      CHris
      • audiman
        • 4827
        I have never driven non-torsen car, so i dont know. I belive the strongest gearbox is the 016, but that to has short ratios IIRC.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Baldy
          • 469
          i'll go out in mine 2mrw n tell you what it can do in each gear
          i know redline 4th is 115mph
          and 5th is the otherside of 160
          0-60 4.9
          1/4mile 13.5
          • Stick Insect
            • Dec 2003
            • 2338
            Can we watch for the flashing lights behind you?
            David
            • Stick Insect
              • Dec 2003
              • 2338
              frightened yet?
              • caterpillar
                • 2480
                send me a PM .have the gearkode and diffcode at home on pc.....at the gearboxes you have the gearkode betveen the upper bolts at the clutchhousing....F,x: AXF,or CBL.......and som nr.....on the diff there are stamped UNDER the housing...f,x AAT or AEC......
                • Baldy
                  • 469
                  David
                  it wasnt flashing lights i was worrying about it was mi mate in his S2
                  0-60 4.9
                  1/4mile 13.5
                  • Baldy
                    • 469
                    he couldnt quite catch mi though
                    0-60 4.9
                    1/4mile 13.5
