Currently my S2 has the ABS light on and the diff is locked permanently... regardless of speed. Diff lock button does not work and is not illuminated.
I'm in the process of diagnosis, so any info on what to check and in what order would be great. It's had the gearbox & clutch out recently, together will all the suspension off to swap springs... so I'm thinking it may just be a sensor or alike which has not been put back correctly.
In the mean time, I've disconnected the diff controller so to disengage the diff lock. Are there any ill effects of disconnecting the diff controller and continuing to drive the car?
Mick
Mick
