UrS6 - New Sachs Clutch Kit - Part Number ?
    Is the part number 3000 951 052 the correct part number for a clutch kit for a later model UrS6 2.2L 20vt ?
    And if it is, what are the three parts that come in the kit ?
    Are they the cover plate, the disc, and the bearing ?
    Will there be a problem with the plastic bearing that the kit presumably comes with for regular road use ?
    Is a metal one a better bet, but only really necessary for tuned UrS6 cars?
    Is the metal one noisier in daily use ?
    Has anyone any photos of the UrS6 clutch kit that they bought in the past ?
    Thanks for any replies to the barrage of questions.
    Does anyone know what the next step up in terms of performance over the standard Sachs clutch kit ?
    i.e. good for less than 400bhp ?
    Will the standard Sachs clutch kit do 380bhp?
    Car is not tracked or launched ever.
    Are the strength / performance of the standard clutches for the RS2 / S2 (aby) / UrS6 (AAN) all the same ?
    Thanks.
      The OE PN for a "clutch set" (pressure plate, disc and throw-out bearing) is 034198141AX which when you throw it into a Google Search does return with a Sachs 3000 951 052. I see the pressure plate and the disc but no throw-out bearing
      http://www.autoteiledirekt.de/oenumb...198141ax.html#
      Which is confirmed by getting into the SACHS web catalog: https://webcat.zf.com/
      SACHS 3000 951 052 Kupplungssatz (Clutch kit)
      Durchmesser [mm]: 240 Zähnezahl: 23
      Einzelteile siehe Stückliste:
      3082 308 042 ( Kupplungsdruckplatte / 1 Stück ) (Clutch plate)
      1864 528 441 ( Kupplungsscheibe / 1 Stück )(Clutch disc)
      3151 271 937 ( Ausrücklager / 1 Stück ) (throw-out/release bearing)
      4200 080 060 ( Fett (Hochleistungsgleitfett) / 1 Stück ) (High performance grease)
      Sachs also has performance clutches as well as OE kits, eg:
      https://www.sachsperformance.com/sac...8/1991-06/1994
      IF you want more contact EFI Express. They sell Southbend performance clutches that will handle as much as you are contemplating.
      http://www.efiexpress.com/catalog/index.php?cPath=8
      PS: New OE LUK clutch kits can handle 380 RS2'd AAN hp without issue (*IF* you don't abuse it with launches)
      • Jukums
        • May 2015
        • 2
        • Country: Latvia
        Has anyone some information how much Nm can hold this AAN 2.2 20VT Clutch plate 3082308042 ?
        I have some issues with it, so I want to know if there is some problem in clutch system or I am reached that limit, what can be hold with this plate.
        Only difference, I am using it on 1.9TDI, with many modifications.
