Flywheel pins
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Flywheel pins
    Hi guys,I have got SMF for my ABY but there is 2 pins missing and I'm not sure if that's essential to have them or not.Another question is ,timing pin,is it so important to modify it like on DMF?Is it will do the modification,is it exactly to be welded on in location of the oryginal pin?
  • Mikes2
    • 1704
    not 100% required as they're on the clutch side rather than engine side
    Mike
    http://www.s2-audi.co.uk
    • piotr
      • Jul 2012
      • 1470
        The flywheel pin works fine, I've used a 3B and 7A both with the pin rather than the welded ABY item.
        • piotr
          • Jul 2012
          • 1470
          In that case I think I will stick with oryginal pin as it's nothing wrong with it .cheers for that
          • AndyP
            • 6049
            While you've got the flywheel off you might aswell 'future proof' it and weld the pin, see my experience here.
            • piotr
              • Jul 2012
              • 1470
              Ok,I got your point Andy ,but thing that worries me is that the engine and flywheel was already balanced with standard pin
              Now I don't know how much this larger pin will effect it?
              • AndyP
                • 6049
                Mine was already balanced when I added the welded pin, that's why I kept it as small as possible, not noticed any difference since it was fitted.
                • piotr
                  • Jul 2012
                  • 1470
                  Thank you for that
