Years ago I had my cats swapped for resonators
Recently my car has developed a leak in the drive train above the cat area (so maybe the extra heat has caused this).
I've been under the car but cannot see a drain port in this area. I assumed this is the centre differential and if so is there a drain and fill port that area that I should be seeing?
cheers
Recently my car has developed a leak in the drive train above the cat area (so maybe the extra heat has caused this).I've been under the car but cannot see a drain port in this area. I assumed this is the centre differential and if so is there a drain and fill port that area that I should be seeing?
cheers
